SFTP add-on works with basic JFileUpload and all others derivated products such as JDiskExplorer, JBatchUpload, JImageFilter and JImageUpload. It provides the following:
* SSH2 protocol support.
* SSH File Transfer Protocol support v0, v1, v2 and v3.
* Resume support.
* Commands support (delete, rename, mkdir, chmod).
See: http://www.jfileupload.com/products/sftp/index.html
SFTP supportRe: SFTP supportHi, i'm using Jfileupload entreprise :
I'm trying to test your sftp addon using the one downloadable on site ... (not the enterprise version i think ) when i try to display applet using applet_sftp.html and applet_sftp.js ... Here's the error i get in java console : Exception in thread "AWT-EventQueue-2" java.lang.NullPointerException at java.awt.LightweightDispatcher$3.run(Unknown Source) at java.awt.event.InvocationEvent.dispatch(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source) Is it due to sftp version ? In this case can you provide me a link with good version to test with my jfileupload enterprise 2.6 please. Thanks Re: SFTP supportTo make test you would need to install JFileUpload Pro + SFTP Pro. You just need to copy the JAR files, it does not affect your JavaScript. We don't have SFTP Enterprise test version, you can only purchase it. That's why Pro version are available for everyone as trial on our web site.
Could it fit to your need? Re: SFTP supportCan someone list the steps required to use keys with the sftp applet?
Thanks. Re: SFTP supportYou have to add:
<PARAM NAME="param5" VALUE="keyfile"> <PARAM NAME="param5" VALUE="file:///c:/folder/id_rsa.txt"> Assuming that the private key is stored on c:/folder/id_rsa.txt file in local file system of end-user. |
