S3 Mulitpart sample with JSAPI
Amazon S3 upload add-on.
Please find enclosed a ready-to-use sample with S3 add-on + JSAPI to get JavaScript notifications.
s3_jsapi.zip
(754.41 KiB) Downloaded 2235 times
Re: S3 Mulitpart sample with JSAPI
And for renaming onfly:
<PARAM NAME="template" VALUE=":name:_:timestamp::extension:|:regex=[^a-zA-Z0-9_\\-\\.]::">
abc 123 s$!%a.properties
becomes:
abc123sa_1362469749458.properties
t.montour
Post by t.montour »
I know this is an old post but do you by chance have the s3_jsapi.zip file still. I'm having the same issue with the functions not being called after it finishs uploading.
but when I try to download the zip file it won't extract.
