Change local home directory
mooz
Post by mooz »
As it is it points to the users my documents folder in windows. Any way to point it to another location?
David
Re: Change local home directory
Yes, you can try to uncomment:
#panel.local.combobox.lastdir=home
in i18n_pane.properties
You can also try to set startdir parameter:
<PARAM NAME="startdir" value="c:/">
Does it help?
