Dialog focus bug FF3.6 Mac
plimpton
Post by plimpton »
With the update from 2.3 to 2.5 the dialog box used for authentication cannot receive keyboard focus on Mac using Firefox 3.5.8 and 3.6
This appears only when using Mac FF and not Safari
Re: Dialog focus bug FF3.6 Mac
And it works with 2.3 ? Some users report issue about FF 3.6.
plimpton
Post by plimpton »
yes, we have to do browser sniffing in order to get it functioning
And which JRE version are you using ? 1.6.0_18 ?
plimpton
Post by plimpton »
I'm using the default install of 1.5.0_22 from Apple Inc as determined by http://javatester.org/version.html
plimpton
Post by plimpton »
I'm using OSX 10.5.8 just in case you needed to know that too
plimpton
Post by plimpton »
Just updated to 1.5.0_24 and the problem still exists
