Can't find bundle for base name i18n_s3, locale en_US
Amazon S3 upload add-on.
nwolf
Post by nwolf »
i get this exception from jfileUpload with s3 addon:
Jun 3, 2009 2:29:31 AM jfileupload.upload.client.MApplet <init>
INFO: JFileUpload 2.4 Build FINAL.001
java.util.MissingResourceException: Can't find bundle for base name i18n_s3, locale en_US
at java.util.ResourceBundle.throwMissingResourceException(ResourceBundle.java:1521)
at java.util.ResourceBundle.getBundleImpl(ResourceBundle.java:1260)
at java.util.ResourceBundle.getBundle(ResourceBundle.java:715)
at jfileupload.transfer.client.util.E.A(Unknown Source)
at jfileupload.transfer.client.util.Conf.G(Unknown Source)
at jfileupload.transfer.client.util.Conf.B(Unknown Source)
at jfileupload.upload.client.MApplet.init(Unknown Source)
at sun.applet.AppletPanel.run(AppletPanel.java:424)
at java.lang.Thread.run(Thread.java:619)
any workaround?
Re: Can't find bundle for base name i18n_s3, locale en_US
Are you able to access i18n_s3.properties directly in browser with:
http://yourserver.com/something/i18n_s3.properties
If not then it means your web server doesn't server .properties files. Then map ".properties" to "text/plain" in web server mime-type section.
Does it help ?
nwolf
Post by nwolf »
there is no i18n_s3.properties file.
just i18n_bar_s3.properties and i18n_helper_s3.properties comes from the zip downloaded from this site
nwolf
Post by nwolf »
yes I can
So, it should work. Where are these files ? In the same folder as the JavaScript ?
Could you provide a testing URL ?
nwolf
Post by nwolf »
i've solved this.
i've changed <param name="resources" value="i18n_s3">
to <param name="resources" value="i18n_bar_s3">
