I have a customer getting a 407 error due to their proxy when trying to use the JS3Upload. I've set the authentication parameter to auto but they are not prompted and still receive the same error. Can you confirm if this setting should work in this situation or if any additional configuration is required?
Thanks.
407 Proxy Authentication RequiredRe: 407 Proxy Authentication RequiredTry to add:
<PARAM NAME="authentication" VALUE="auto"> Re: 407 Proxy Authentication RequiredI already have this set in the JS file: document.writeln('<PARAM NAME="authentication" VALUE="auto">'); Should there be a prompt for credentials where required? Re: 407 Proxy Authentication RequiredYes, this option will display authentication pop-up when required. Are you sure you've this parameter twice for cross browser support?
Re: 407 Proxy Authentication RequiredYes, I have both:
document.writeln('<PARAM NAME="authentication" VALUE="auto">'); and document.writeln('<PARAM NAME="authentication" VALUE="auto">'); specified in the applet_s3_multipart.js |
