Maximum File Size to Upload to Amazon S3
Amazon S3 upload add-on.
garethtdavies
Post by garethtdavies »
I know that the maximum filesize in an Amazon bucket is 5Gb but how can you upload a large file to Amazon through JS3Upload as I hit a
"Error : HTTP/1.0 413 Request Entity Too Large" for anything greater than about 100Mb?
Ideally I'd like to be able to uplad upto 1Gb on one go. Do I need to split and recombine it?
Cheers.
Re: Maximum File Size to Upload to Amazon S3
Yes, it should be able to upload 5GB without any split.
Did you setup any maxsize in your applet parameter ?
Do you get this error when you start to upload or at then end ?
garethtdavies
Must be the network I am on as I'm behind a company firewall. I just tried from a different location and it uploaded a 450Mb file :D
Ok, great.
I've checked the S3 developer documentation and it reports that it's 5GB max even for POST upload.
