[{2} files left] message is wrong when connection breaks
Bogdan
Post by Bogdan »
Number of files left keep decreasing with every upload retry, even files are not being uploaded.
Steps to reproduce:
1) This is harder to reproduce when a file is split. So turn off chuncking of set chunksize larger than the file size
2) Drop N > 1 files into jBatchUpload
3) Start sending
4) Pull the network cable (or disable the network connection)
5) See the status message, every [retryinterval], number of "files left" keeps decreasing!
--Reason--
in "\src\jfileupload\transfer\client\mdesign\ProgressPanel.java", variable [remaining] is decreased on transferStarted()
--Fix--
Move line:
if ((amount > 0) && (remaining > 0) && (fchunkid == 1)) remaining--;
to transferCompleted()
--Note--
This actually helps with other annoyance, because now number of "files left", is really of those left to upload, not MINUS ONE like it used to!
src.zip
(6.92 KiB) Downloaded 1305 times
Re: [{2} files left] message is wrong when connection breaks
Thanks for the report.
