BUG in jBatchUpload - ziponfly, zipignorelist, chunkmode
Bogdan
Post by Bogdan »
Disclaimer: I know I've been writing here about bug a lot, and I may be annoying you already, but this one is real pain and I couldn't fix it myself for hours today..
Interesting BUG, file doesn't get deleted from the list IF following is specified
document.writeln('<PARAM NAME="ziponfly" VALUE="zip">');
document.writeln('<PARAM NAME="zipignorelist" VALUE="*.zip,*.pdf,*.gif,*.jpg,*.jpeg">');
document.writeln('<PARAM NAME="chunkmode" VALUE="onfly">');
document.writeln('<PARAM NAME="chunksize" VALUE="N">');
And I upload a file that is
1) bugger than "chunksize", so it needs to be split
2) file extension is IN "zipignorelist", so it's not compressed
NOTE: problem happens only in circumstances described, it will not happen if any of params are removed.
See attached
applet_http_batchupload.zip
(2.1 KiB) Downloaded 1299 times
Re: BUG in jBatchUpload - ziponfly, zipignorelist, chunkmode
Thanks for the report. Fixed in 2.5.
