With pleasure I receive 2.2beta upgrade with watermarking capabilities on image files.
At this time I am resizing-uploading only one image.
On server side I create a small thumbnail for it.
Of course if the regular image is watermarked same is applied to the thumbnail.
My question is if I use the applet to upload both images from client side (two images upload)
document.writeln('additionalfilterid ="medium,small"');
watermark would be applied to both?
I think thumbnails (small sample) do not need it regularly.
Thank you,
Daniel
About watermarkingRe: About watermarkingYou can define one scaling.properties file for each filter small and medium :
<PARAM NAME="smallfilterproperties" NAME="small_scaling.properties"> <PARAM NAME="mediumfilterproperties" NAME="medium_scaling.properties"> So you can enable/disable watermark in each file depending on your needs. Does it help ? Re: About watermarkingYes, it does. Thank you.
PS: I have a pending answer about broken uploads |
