I'm playing around with the JImage upload and I have the overwrite parameter set for "indexrename" and the i18 file set to always remove after upload......but it seems that if it has renamed due to a duplicate it does not remove the thumbnail from the upload panel. Can you change this behavior so they are removed even on rename.
Thanks, Dan
