Hi i just installed both jfileupload and jimageupload licenses on my system, but still get the UNREGISTERED message above, I'm working on the developer's site which is local and of course different from the registered .com site, i don't know if it has something to do with it.
Any advice will help a lot
thanks.
JImageUpload licenseRe: JImageUpload licenseYou will get "UNREGISTERED" message if you don't have the domain name you've registered for in the url. For instance, if you've registered for http://www.myserver.com and if you're testing it under http://www.mytestserver.com then you will still have the "UNREGISTERED" message.
