JFileUpload function
import
Post by import »
I try JFileUpload demo.
But i can't use all parameters. (blacklist,etc...)
It's limited on this version, or I make not correctly?
Thx for reply
import
Re: JFileUpload function
Post by import »
Trial version is a full version. You should be able to use blacklist and any parameter. You have samples in documentation/ folder.
import
Post by import »
Ok, thx it works.
