SSL IssuesSSL IssuesI am using the weakssl jar with version 2.8, but am getting "This websites certificate cannot be verified" message. The server is certified under GoDaddy.
Re: SSL IssuesThere is a problem with the SSL certificate. It's at JRE level and not applet itself so we cannot control it. There could be 2 workaround:
#1: Server JAR files with HTTP and not HTTPS #2: Import your SSL certificate (or GoDaddy root certificate) in Java Control panel. |
