v2.7 using post and postparameters = true works in Chrome but not Firefox or Safari (I am not worried about IE). In all cases these are current/new stable release versions of browsers.
All i can confirm from debugging is that there are no client-side scripting errors, the files are uploaded correctly, however no post is performed for Firefox and Safari.
I did a test with forward and that works fine however does not suit the implementation solution I have in mind by using post/postparameters.
Any suggestions where the problem may be?
post / postparameters not working Firefox / SafariRe: post / postparameters not working Firefox / SafariDo you have any traces on server-side to check that a call has been performed by applet?
Re: post / postparameters not working Firefox / SafariTraces: Yes I logged activity to the POST location
POST is performed by Chrome but nothing is logged by other browsers. Although postparameters = true no additional data apart from params passed in POST url are shown. My POST URL passes method and session params. I testes without URL parameters and that made not difference in non-working browsers. The agent in Chomre is shown as Mozilla/4.0 (Windows XP 5.1) Java/1.6.0_26 I also updated to v2.8 and this made no difference. Re: post / postparameters not working Firefox / SafariDo you have a testing URL? If yes, send it to support(at)jfileupload(dot).com
