Not redirecting to next page
jeevesh
Post by jeevesh »
My configured JFileUpload is working fine but it creates problem when I try to upload bigger file (>100mb). In that case it doesn't redirect to the next page.
What might be the reason.
Regards,
Jeevesh
Re: Not redirecting to next page
Are you using FTP or HTTP upload?
CMSupport
Post by CMSupport »
I am encountering the same issue. It is with the http upload.
Do you have any error in JavaScript console. If JavaScript is broken then it could explain why "forward" or "post" parameter is not loaded.
tejas.j654
Post by tejas.j654 »
I'm facing the same problem with the forward. I'm using FTP and the upload size is less than 10 MB.
The parameter is set in applet since I can see it in debugger console. I'm using FTP, Batch upload together with SFTP.
