Please let me know how to test the resume feature. I have added the below code in my jupload script file.
document.write('<PARAM NAME="value8" VALUE="put">');
I have also modified the process.php for the same. Please help ?
Resume problemRe: Resume problemIn the JavaScript, you need to add:
document.write('<PARAM NAME="resume" VALUE="true">'); Also in the PHP, replace: $max_size = 1500000; $resume = "false"; by: $max_size = 150000000; $resume = "true"; Then to try it: Start uploading a file ... after 30% upload press "Cancel" button. Select the same file and try to upload it again. It will restart from 30% to 100%. Re: Resume problemI have made the mentioned changes, but when I try to upload the file. I got the below error
Select or drag and drop file to upload -------------------------------------------------- Uploading : bday.bmp (122,038 bytes) Upload started ...Server error HTTP/1.1 403 Forbidde My php script file works fine if I do not add below 3 lines. document.writeln('<PARAM NAME="resume" VALUE="true">'); document.writeln('<PARAM NAME="param8" VALUE="httpmethod">'); document.writeln('<PARAM NAME="value8" VALUE="put">'); Please help. Regards, Manish Re: Resume problemWhich web server are you using ?
HTTP 403 means forbidden. HTTP PUT may not be in the allowed HTTP verbs. It's the default setup for IIS with PHP. You need to make sure PUT is allowed. |
