document.writeln('<PARAM NAME="resume" VALUE="true">');
Resume command doesn't workResume command doesn't workWhat do I need to do to get the resume function appear & work iwth my jfileupload? I have the pro version, and I have included the following line in my js file:
Thanks Re: Resume command doesn't workAre you using HTTP or FTP upload? If HTTP, which server-side script are you using?
Re: Resume command doesn't workI am using FTP.
Re: Resume command doesn't workIt should work. Are you using Windows FTP server? or Linux/Unix.
Re: Resume command doesn't workIt is Linux/Unix. I have tried it on three different servers, all the same - no button.
Re: Resume command doesn't workCould you send a testing FTP account to support(at)jfileupload(dot)com?
Re: Resume command doesn't workI have same issue Resume command dosen't work and I m using HTTP uploading. AS I am new for JFileUpload. Please guide me...
document.writeln('<PARAM NAME="resume" VALUE="true">'); Thanks Hitesh shah |
Sitemap | Privacy Statement | All company and/or product names are the property of their respective owners.
