Firefox 4 for Mac OS, drag&drop problemFirefox 4 for Mac OS, drag&drop problemHi,
I have two Mac OS users that have recently updated their browsers to Firefox 4 and since then they have been unable to use the JFileUpload applet. The applet loads fine, but when the user tries to drop a file over it, the file just goes back to its place and JFileUpload doesn't register the file drop. ----------- User 1------------------- OS: Mac OS X 10.6.7 Java: Java Platform Standard Edition 6, Version 13.4.0 (13.4.0) Java Plugin: Java Plug-In 2 for NPAPI Browsers 13.4.0 Browser: Firefox 4.0 ----------- User 2------------------- Mac OS 10.5, Java SE 6, 64 bit, Firefox 4: Java Plug-in 1.6.0_24 -------------------------------------- I am afraid that more users will upgrade to Firefox 4 and if all of them will be having this problem, I will get buried in complaint e-mails. So I would really appreciate some help with this Thanks! Re: Firefox 4 for Mac OS, drag&drop problemIssue is only under MacOSX? I've tried FF4 under WindowsXP and it works.
Re: Firefox 4 for Mac OS, drag&drop problemIt seems to be a general issue for all applets. Drag&Drop support is broken in FF4 on MacOSX.
Performances issues are reported too: http://support.mozilla.com/en-US/questions/796196 Re: Firefox 4 for Mac OS, drag&drop problemWe are getting reports from our Chrome users as well. Only in this case:
-Drag image to D&D uploader -When images is dropped, uploader is replaced with full-size image that was dropped and otherwise blank page (no tool/action bars). It is Mac OS only - our support staff has verified it. (We thought users were dragging outside of D&D pane, but they were not) Using 'Browse' button functions properly. Re: Firefox 4 for Mac OS, drag&drop problemIt looks like the same problem.
Re: Firefox 4 for Mac OS, drag&drop problemI have another user complaining about the same problem, but he's using Safari 5.1
I'm starting to think that this is either a JFileUpload bug or Java. Re: Firefox 4 for Mac OS, drag&drop problemIt should be fixed in FF. See:
viewtopic.php?f=5&t=698&start=10#p2886 Re: Firefox 4 for Mac OS, drag&drop problemYour demo site:
http://www.jfileupload.com/products/dem ... _http.html Dropping file does not works in Firefox 5.0.1 on Mac. Re: Firefox 4 for Mac OS, drag&drop problemI found the following message: http://lists.apple.com/archives/java-de ... 00083.html
Seems to be a general issue with Java on Mac OS. Re: Firefox 4 for Mac OS, drag&drop problemIt seems to be fixed now:
viewtopic.php?f=5&t=698&p=2891&hilit=firefox#p2886 |
