Recently, I made changes to scaling.properties
metadata=all
impl=awt
At the time of the error JAVA console showed this
[INFO] JSMApplet - JSAPI 2.8
[INFO] ImageFilter - Passing all metadata []: javax_imageio_jpeg_image_1.0
[INFO] HTTPUploadTransfer - Upload failed
Reverting back produced mixed results amongst our testers, but I thought in mine that changing back to
metadata=unknownmarker
fixed it. However, with a default metadata.error=ignore I would not think this would be the cause.
Any insights on where to look and how to test?
javax.imageio.IIOException: Missing Huffman code table entryRe: javax.imageio.IIOException: Missing Huffman code table eUse metadata=unknownmarker because using metadata=all will try to forward meta-data from original to scaled image that are often not compatible. For instance, compression or dimensions information.
Re: javax.imageio.IIOException: Missing Huffman code table eWell, I was hoping to be able to use metadata=all because when an image with a compression of 75 has a 90 compression applied, it suffers a size bloat and I was hoping to reverse that.
But, I have seen that it does not pass the original compression value anyway. Additionally, I thought metadata.error=ignore was supposed to prevent errors? So unless I am missing something, I am seeing 2 things that do not work as expected. Re: javax.imageio.IIOException: Missing Huffman code table ePlease send a testing image with this issue to support(at)jfileupload(dot)com
