Server error HTTP/1.1 405 Method not allowed
pady
Post by pady »
Hi ,
I hv created virtual directory and when i m applet_http.html , after selecting file i m getting error Uploading : Book1.xls
(23,552 bytes)
Upload started ...Server error HTTP/1.1 405 Method not allowed.
And My Javascript setting are are.
document.writeln('<PARAM NAME=ARCHIVE VALUE="lib/jfileupload.jar,lib/httpimpl.jar,lib/chttpclient.jar,lib/clogging.jar">');
document.writeln('<PARAM NAME="url" VALUE="http://localhost/jupload2.6/upload/process.jsp">');
Please help me.
I want to add this in my asp.net application for Demo.
I m using trail version 2.6.
Plz suggest.
Regards,
Pady
Re: Server error HTTP/1.1 405 Method not allowed
For ASP.NET you need install ASP.NET script on server-side to handle upload requests:
Then you have to update "url" parameter in the JavaScript accordingly.
Does it help?
willeha
Post by willeha »
I have the same error, but I'm not using ASP.NET.
I'm using Oracle on a windows server...
Does anybody know what the problem is? Or do you need more info?
Which server-side script are you using to handle upload?
willeha
Post by willeha »
We have a windows server with Oracle (APEX).
I don't know how Oracle server work but I guess you've installed a script to handle upload request, correct? Is it JSPUpload?
willeha
Post by willeha »
Yes, there was a JSPUpload installed (and we just moved everything to the other server).
We use an Oracle database and an apache server.
ok, could you try http://yourserver.com/something/process.jsp in your browser?
You should see a simple HTML upload form, try to upload a file from it and see if it works. If not then it cannot work with the applet.
