Hello.
Before downloading the 6.20 version of Java, uploading and resuming worked (via http). However, after downloading and installing 6.20, problems came during uploads. Examples of errors:
1. The speeds of upload would go up to 8000kbps (from where we are, thats not the speed we have)
2. Status would indicate complete 100%, but then it would try to reupload the same file again, up to the number of times we specified the retries. In reality, the upload was only partials.
What worked before was using the older copy of Jfileupload and the older version of Java. Now with both Jfileupload updated (2.6) and Java to 6.20, these problems occured.
Thanks for helping.
Regards,
Jm.
Here is the java console messages:
Java Plug-in 1.6.0_20
Using JRE version 1.6.0_20-b02 Java HotSpot(TM) Client VM
User home directory = C:\Users\abc project
c: clear console window
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
security: property package.access value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.
security: property package.access new value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.javaws
security: property package.access value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.javaws
security: property package.access new value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.javaws,com.sun.deploy
security: property package.access value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.javaws,com.sun.deploy
security: property package.access new value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.javaws,com.sun.deploy,com.sun.jnlp
security: property package.definition value null
security: property package.definition new value com.sun.javaws
security: property package.definition value com.sun.javaws
security: property package.definition new value com.sun.javaws,com.sun.deploy
security: property package.definition value com.sun.javaws,com.sun.deploy
security: property package.definition new value com.sun.javaws,com.sun.deploy,com.sun.jnlp
security: property package.access value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.javaws,com.sun.deploy,com.sun.jnlp
security: property package.access new value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.javaws,com.sun.deploy,com.sun.jnlp,org.mozilla.jss
security: property package.definition value com.sun.javaws,com.sun.deploy,com.sun.jnlp
security: property package.definition new value com.sun.javaws,com.sun.deploy,com.sun.jnlp,org.mozilla.jss
basic: Added progress listener: sun.plugin.util.GrayBoxPainter$GrayBoxProgressListener@56a499
basic: Plugin2ClassLoader.addURL parent called for http://abc.com/lib/jfileupload.jar
basic: Plugin2ClassLoader.addURL parent called for http://abc.com/lib/httpimpl.jar
basic: Plugin2ClassLoader.addURL parent called for http://abc.com/lib/chttpclient.jar
basic: Plugin2ClassLoader.addURL parent called for http://abc.com/lib/clogging.jar
security: Blacklist revocation check is enabled
security: Trusted libraries list check is enabled
network: Cache entry found [url: http://abc.com/lib/jfileupload.jar, version: null] prevalidated=true/0
network: Connecting http://abc.com/lib/jfileupload.jar with proxy=DIRECT
network: Connecting http://abc.com:80/ with proxy=DIRECT
network: Connecting http://abc.com/lib/jfileupload.jar with cookie "PHPSESSID=b599d2eef95de627a9c231bd592760dd"
network: ResponseCode for http://abc.com/lib/jfileupload.jar : 304
network: Encoding for http://abc.com/lib/jfileupload.jar : null
network: Disconnect connection to http://abc.com/lib/jfileupload.jar
cache: Reading Signers from 2701 http://abc.com/lib/jfileupload.jar | C:\Users\abc\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\16\4601e810-64dffde6.idx
cache: Read manifest for http://abc.com/lib/jfileupload.jar: read=107 full=2626
basic: Plugin2ClassLoader.getPermissions CeilingPolicy allPerms
network: Cache entry found [url: http://abc.com/lib/httpimpl.jar, version: null] prevalidated=true/0
network: Connecting http://abc.com/lib/httpimpl.jar with proxy=DIRECT
network: Connecting http://abc.com/lib/httpimpl.jar with cookie "PHPSESSID=b599d2eef95de627a9c231bd592760dd"
network: ResponseCode for http://abc.com/lib/httpimpl.jar : 304
network: Encoding for http://abc.com/lib/httpimpl.jar : null
network: Disconnect connection to http://abc.com/lib/httpimpl.jar
cache: Reading Signers from 2701 http://abc.com/lib/httpimpl.jar | C:\Users\abc\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\22\65a35396-1c86cd12.idx
cache: Read manifest for http://abc.com/lib/httpimpl.jar: read=551 full=551
network: Cache entry found [url: http://abc.com/lib/chttpclient.jar, version: null] prevalidated=true/0
network: Connecting http://abc.com/lib/chttpclient.jar with proxy=DIRECT
network: Connecting http://abc.com/lib/chttpclient.jar with cookie "PHPSESSID=b599d2eef95de627a9c231bd592760dd"
network: ResponseCode for http://abc.com/lib/chttpclient.jar : 304
network: Encoding for http://abc.com/lib/chttpclient.jar : null
network: Disconnect connection to http://abc.com/lib/chttpclient.jar
cache: Reading Signers from 2701 http://abc.com/lib/chttpclient.jar | C:\Users\abc\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\15\6e31150f-310a39ea.idx
cache: Read manifest for http://abc.com/lib/chttpclient.jar: read=110 full=6607
network: CleanupThread used 186980 us
network: Cache entry found [url: http://abc.com/lib/clogging.jar, version: null] prevalidated=true/0
network: Connecting http://abc.com/lib/clogging.jar with proxy=DIRECT
network: Connecting http://abc.com/lib/clogging.jar with cookie "PHPSESSID=b599d2eef95de627a9c231bd592760dd"
network: ResponseCode for http://abc.com/lib/clogging.jar : 304
network: Encoding for http://abc.com/lib/clogging.jar : null
network: Disconnect connection to http://abc.com/lib/clogging.jar
cache: Reading Signers from 2701 http://abc.com/lib/clogging.jar | C:\Users\abc\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\1\790161c1-57dbe3cc.idx
cache: Read manifest for http://abc.com/lib/clogging.jar: read=903 full=903
network: Cache entry not found [url: http://abc.com/, version: null]
network: Connecting http://abc.com/commons-logging.properties with proxy=DIRECT
network: Connecting http://abc.com/commons-logging.properties with cookie "PHPSESSID=b599d2eef95de627a9c231bd592760dd"
network: Cache entry not found [url: http://abc.com/org/apache/commons/loggi ... gger.class, version: null]
network: Connecting http://abc.com/org/apache/commons/loggi ... gger.class with proxy=DIRECT
network: Connecting http://abc.com/org/apache/commons/loggi ... gger.class with cookie "PHPSESSID=b599d2eef95de627a9c231bd592760dd"
Jun 25, 2010 6:00:35 PM jfileupload.upload.client.MApplet <init>
INFO: JFileUpload 2.6 Build FINAL.001
basic: Applet loaded.
basic: Applet resized and added to parent container
basic: PERF: AppletExecutionRunnable - applet.init() BEGIN ; jvmLaunch dt 4616803 us, pluginInit dt 13407637 us, TotalTime: 18024440 us
network: Cache entry found [url: http://abc.com/i18n.properties, version: null] prevalidated=false/0
network: Connecting http://abc.com/i18n.properties with proxy=DIRECT
network: Connecting http://abc.com/i18n.properties with cookie "PHPSESSID=b599d2eef95de627a9c231bd592760dd"
network: ResponseCode for http://abc.com/i18n.properties : 200
network: Encoding for http://abc.com/i18n.properties : null
network: Disconnect connection to http://abc.com/i18n.properties
network: CleanupThread used 6 us
network: Downloading resource: http://abc.com/i18n.properties
Content-Length: 7,702
Content-Encoding: null
network: Wrote URL http://abc.com/i18n.properties to File C:\Users\abc\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\63\4423bebf-4e0136ec-temp
cache: Replacing MemoryCache entry (cnt=0) for http://abc.com/i18n.propertieswas=com.s ... CacheEntry (3210271) now=com.sun.deploy.cache.CacheEntry (33066941)
Jun 25, 2010 6:00:37 PM jfileupload.transfer.client.core.E W
INFO: Filter[preprocessing] instantiated: jfileupload.transfer.client.core.ArchiveFilter
Jun 25, 2010 6:00:37 PM jfileupload.transfer.client.core.ArchiveFilter A
INFO: Initializing Archive Filter [preprocessing]
network: Connecting http://abc.com/upload/process.php with proxy=DIRECT
Jun 25, 2010 6:00:38 PM jfileupload.transfer.client.http.F C
INFO: Auto-detect proxy settings (ps): DIRECT
INFO: Auto-detect proxy settings : host = null
INFO: Auto-detect proxy settings : port = -1
basic: Applet initialized
basic: Removed progress listener: sun.plugin.util.GrayBoxPainter$GrayBoxProgressListener@56a499
basic: Applet made visible
basic: Starting applet
basic: completed perf rollup
basic: Applet started
basic: Told clients applet is started
Jun 25, 2010 6:00:57 PM jfileupload.transfer.client.core.ArchiveFilter B
INFO: Compression started : C:\Users\LIMFAM~1\AppData\Local\Temp\Final Print 10x20.zip
Jun 25, 2010 6:01:08 PM jfileupload.transfer.client.core.ArchiveFilter B
INFO: Compression completed
Jun 25, 2010 6:01:10 PM jfileupload.transfer.client.http.F A
INFO: Head Status code = 404
Jun 25, 2010 6:01:10 PM jfileupload.transfer.client.http.HTTPUploadTransfer E
INFO: Upload (PUT) started : C:\Users\LIMFAM~1\AppData\Local\Temp\Final Print 10x20.zip (http://abc.com/upload/process.php)
re: Errors uploading after updating to Java 6.20.Re: re: Errors uploading after updating to Java 6.20.Could you try to clean your Java cache? Also, could you try an upload with our online demonstration:
http://www.jfileupload.com/products/dem ... _http.html Re: re: Errors uploading after updating to Java 6.20.I have a similar problem.
I cleared my cache and try your demo and it works. But! your site uses version 2.7!!!! Re: re: Errors uploading after updating to Java 6.20.Try to install JFileUpload 2.6. 2.7 will be available officially soon.
