Change port
luctuf
Change port
Post by luctuf »
Hi to all! I would like to change the ports (both 20 and 21) in the applet. My configuration:
Internet >> Router >> Firewall/Proxy >> FTP server
If i setup an FTP standard rule (port 20,21 on FTP server port 20,21), the applet works fine! Unfortunately I've another FTP server and I cannot use the rule one the FW! If I set the port in the url, it only affects the 20 port but not the 21: in fact i see that the login is successful (port 20) but the file transfert does not start (port 21). there is a parameter that I can use to change the ports? Otherwise, how can I solve this problem?
thaks in advance! :D
Re: Change port
No, you can only change the port in URL such as:
ftp://yourserver.com:21
Updating the other port would require some customization. If you're willing to pay for it then we could provide such customization. Please contact support(at)jfileupload(dot)com
