When a user uploads a directory of several files, what is the way to prevent the browser (Firefox) containing the applet is found in the foreground at the beginning of each file transfers. This is indeed difficult for the user when navigating in Firefox when transferring a directory.
Regards,
Java 7 (u17)
JFU2.9
Applet window to the foregroundRe: Applet window to the foregroundYou mean focus?
Re: Applet window to the foregroundYes exactly.
Re: Applet window to the foregroundWe are getting customer complaints about this issue as well. It seems to only be happening on IE (only verified on IE 11 so far). It happens with one large file too if chunking is enabled. Each new chunk will return focus to the browser window for the applet. Is there anything that can be done about this?
Re: Applet window to the foregroundI have managed to identify the problem; it's the communication of the applet with the browser via the javascript API calls. It is happening when each chunk has been uploaded and it's not limited to IE, as it is reproduced with FF as well. For us removing this communication is not an option as we will lose functionality.
Can you please help? Tested with: IE 11, Firefox 26.0 jFileUpload 3.2 JRE 1.7.0_51-b13 Windows 7 SP1 Re: Applet window to the foregroundDid you update JSAPI to 3.2 too?
Re: Applet window to the foregroundYes JSAPI is version 3.2 as well.
