Hello
I am facing trouble with jfileupload when it is behind a reverse proxy microsoft isa 2006
We use jfileupload wiht https and so web server certificates.
There are two certificate : one on the reverse proxy and the other on the server itself. The one on the reverse proxy is a valid certificate, issued by keynectis. The second one is a self sgned certificate from the server.
When i try to upload a file i receive the following message :
Envoi démarré ... Envoi échoué : javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: KeyUsage does not allow key encipherment
Does any one already face same problem ?
Thanks for your answers
Mathias
Jfileupload and reverse proxyRe: Jfileupload and reverse proxyIs the self-signed certificated designed for web server SSL?
Maybe you could try WeakSSL add-on to see if it could be used as workaround. Re: Jfileupload and reverse proxyHello
Weakssl is already installed on the server. At the begenning we have problem with the self signed certificate and we installed it . It works for month and suddenly, about a month ago we started to receive this message. But as far as i know, nothing has changed, nor on the reverse proxy or on the web server Thanks Re: Jfileupload and reverse proxyAny JRE update on client-side?
Re: Jfileupload and reverse proxyUnfortunatly no....
Re: Jfileupload and reverse proxySo what JRE version are you using?
Re: Jfileupload and reverse proxyI am using Java 6 update 22
(build 1.6.0_22-b04) Thanks Re: Jfileupload and reverse proxyWell, JRE doesn't like your certificate. Is it really a SSL certificate? A field 'KeyUsage' is missing a value that seems mandatory for JRE.
