Is it possible to select files that match spcific "file masks" e.g. show only file names that start with "rpt" OR "demofil" OR contains ".TXT"?
When using the below param I get all files EXCEPT the ones I want!? (the pattern has the effect of removing the files I want instead of showing them).
PARAM NAME="filechooserpattern" VALUE="regex=rpt.*|demofil.*|.*\.TXT"
