There is a known drag and drop issue with browsers running on snow leopard and Lion. Until this issue is fixed I was wondering if there is a way to change the text "Select or drag and drop file to upload" in the upload applet. Our users are getting confused with this message so wanted to remove it until the issue is resolved.
Changing Drag & Drop text in upload appletRe: Changing Drag & Drop text in upload appletYes, enable resources parameter an update i18n.properties files, see the following tutorial:
http://www.jfileupload.com/products/jfi ... ation.html |
