Code snip to wrap the applet in a form.
<form action="" method="post">
<input name="test" type="text" size="100">
<br/>
<!-- JFileUpload Applet : Begin copy/paste -->
<script src="applet_http.js"></script>
<!-- JFileUpload Applet : End copy/paste -->
</form>
When the upload applet is used within a html form, on page load the text input fields (text, or textarea) loose the ability to see the cursor or perform edits. If I use the applet control to "file / select files" (and cancel without choosing a file to upload) the html input field usually turns back to normal and you can perform an edit.
On page refresh (F5) the field is again in a bad state, and user input cannot happen.
This problem does not exist in IE, or FF9 etc. It is very odd, as FF10 seems to work quit well on other other pages/forms etc - but acts up with the latest FF update.
Anyone have any suggestions?
Tony
