I currently parameter forward to redirect after the upload to a file php. It works.
To retrieve a list of files upload, I use a parameter forwardparameters to true.
My page forward = fin_trans.php? Filename1 = test.jpg & filename2 = test2.jpg . It works.
But I do not want the url contain filenameX
I added postparameters = true but that does not change.
If I use the POST parameter, I am not redirected.
Thanks for your help.
Use forward AND post AND forwardparametersRe: Use forward AND post AND forwardparametersYou want to get upload files list but not with filenameX, ... ? You can use "post" + "postparameters" + "forward". Then the PHP script will receive the filenames in an HTTP POST request and the applet will forward to fin_trans.php without any parameter.
Re: Use forward AND post AND forwardparametersIt works.
Thanks Laurent |
