Storemodel and MemoryStoreStoremodel and MemoryStoreHi,
I don't understand how to use different storemodel and especially MemoryStore. Do you have an example of using MemoryStore? Moreover, I don't understand how to use the upload when it is stored in memory. Thank you for your return Peter. Re: Storemodel and MemoryStoreIt's the place the file will be stored. Default is on disk in a folder, but it could be in ZIP archive or in memory. Memory does not fit to most usage.
Re: Storemodel and MemoryStoreFirst of all, thank you for your return.
I have a problem with the resume. First, this is my work environment: The applet JFileUpload is in a jsp based on a servlet (processServlet.java) which contains the upload processing (ie which contains the Java code process.jsp). When I upload a file and I cancel it before the end, I can easily resume it ("resume" means : I selected again the same file via the window "File chooser"). However, I can't resume a broken upload : during uploading, I shut down my server to simulate a network failure => when I select the same file again (by choosing the same file through the window "File chooser "), uploading start from scratch. What I note is that when I cancel during the upload, I have the file in my folderstore (of course, it hadn't the well size). However, when I cut my server during the upload nothing is stored in the folderstore. I give you ma applet parameters: <PARAM NAME = "scriptable" VALUE="true"> <PARAM NAME = "url" VALUE="http://localhost:26000/ProtoJFileUpload ... properties"> <PARAM NAME = "post" VALUE="http://localhost:26000/ProtoJFileUpload/ForwardUpload"> <PARAM NAME = "postparameters" VALUE="true"> <PARAM NAME = "paramfile" VALUE="uploadfile"> <PARAM NAME = "param1" VALUE="todo"> <PARAM NAME = "value1" VALUE="upload"> <PARAM NAME = "folderdepth" VALUE="-1"> <PARAM NAME = "param2" VALUE = "relativefilename"> <PARAM NAME = "value2" VALUE = "true"> <PARAM NAME = "param3" VALUE = "notifyrelativefilename"> <PARAM NAME = "value3" VALUE = "true"> <PARAM NAME = "maxsize" VALUE="167772160"> <PARAM NAME = "maxfiles" VALUE="1"> <PARAM NAME = "mode" VALUE="http"> <PARAM NAME = "resources" VALUE="i18n_TestBis"> <PARAM NAME = "whitelist" VALUE="*.zip,*.rar,*.txt"> <PARAM NAME = "verbosemode" VALUE="debug"> <PARAM NAME = "preferences" VALUE="true"> <PARAM NAME = "resume" VALUE="crc"> <PARAM NAME = "param4" VALUE="errorheader"> <PARAM NAME = "value4" VALUE="Error Test 2 !!!"> <PARAM NAME = "shorterrorjs" VALUE = "true"> <PARAM NAME = "param5" VALUE = "cookiename"> <PARAM NAME = "value5" VALUE = "JSESSIONID"> <PARAM NAME = "param6" VALUE = "cookievalue"> <PARAM NAME = "value6" VALUE = "<%= sessionid %>"> <PARAM NAME = "checksum" VALUE = "crc"> <PARAM NAME = "overwrite" VALUE="true"> Thank you, Peter. Re: Storemodel and MemoryStoreDo you have something in tmpdirectory setup in JSPUpload when you kill server while uploading?
Re: Storemodel and MemoryStoreYes, I have a file like that "upload__78cf8552_133b0fa324d__7ff8_00000007.tmp".
Re: Storemodel and MemoryStoreWhen you hist cancel, the tmp file should be copied in final folder. Did you modify anything more (except folders) in process.jsp?
Re: Storemodel and MemoryStoreHi,
I'm agree with you : when i "cancel" the upload, the tmp file is copied in final folder. But when i shut down my WebServer, how it's possible that my application do the same thing => that is to say copy the tmp file in the final folder. You ask me if I changed something in process.jsp. I haven't process.jsp because I use a servlet which contains the upload processing (ie which contains the Java code process.jsp). I try the same thing with process.jsp => when i shut down my WebServer, the tmp file stay in the tmp folder and the final folder is empty. If you want i can show you my servlet but i don't know how i can transfer you a file. Thanks, Peter. Re: Storemodel and MemoryStoreIf you kill server then temporary file may not be copied in final folder.
Re: Storemodel and MemoryStoreHello,
I thought a process during the restart or during the recovery of the upload could identify that there is a tmp file in order to resume the upload. What problems are managed when you talk about "JFileUpload could resume broken upload"? and how ? Thanks, Peter. Re: Storemodel and MemoryStoreBroken upload: Network issue (disconnect) or client-side crash.
