I think I installed well JUpload on my server.
When I try http://myserver.com/applet_http.html in my browser.
That load the applet, prompt for a security pop-up, I accept and this display the applet UI with panel, progress bar and button. I can explore my workstation disk. But when I want to upload a file I've got an error message in the JUpload applet :
Upload started ...Upload failed : java.net.ConnectException: Connection refused
Could you help thank
Upload failed : java.net.ConnectException: Connection refuseRe: Upload failed : java.net.ConnectException: Connection refuseDid you setup "url" parameter in applet_http.js ? "url" parameter must be the server-side script that will handle upload requests (i.e. save file into a folder on server).
We provide free sample script at: http://www.jfileupload.com/products/tools/index.html Does it help ? Re: Upload failed : java.net.ConnectException: Connection refuseI created a new directory where is the index.html is installed
$PATH_HTTPD/docs/tmp I put new restriction like this : drwxrwxrwx 2 nobody nogroup 512 Sep 25 09:19 tmp I modify these following lines of applet_http.js : document.write('url="http://localhost:8080/upload/process.jsp" '); ../.. document.writeln('<PARAM NAME="url" VALUE="http://localhost:8080/upload/process.jsp">'); by these ones : document.write('url="http://myserver.org/tmp" '); .../... document.writeln('<PARAM NAME="url" VALUE="http://myserver.org/tmp">'); When I upload a file to the server, i've got this following error message : Select or drag and drop file to upload -------------------------------------------------- Uploading : File.pdf (428 444 bytes) Upload started ...Server error HTTP/1.1 302 Moved Temporarily Could you help ? Re: Upload failed : java.net.ConnectException: Connection refuseCreating docs/tmp folder is not enough. You do need a server-side script to handle upload requests.
Does your web server support PHP ? If so then use PHP Script at: http://www.jfileupload.com/products/tools/index.html Re: Upload failed : java.net.ConnectException: Connection refuseMy server doesn't support PHP. This is a JAVA server from SUN.
Re: Upload failed : java.net.ConnectException: Connection refuseOk, so you could use JSP upload script:
http://www.jfileupload.com/products/too ... oad2.1.zip 1 - Once downloaded, rename jspupload2.1.zip into upload.war 2 - Then open your Java server web console, deploy the WAR file. 3 - Then go into the directory where the WAR has been deployed, edit process.jsp and setup "directory" and "tmpdirectory" folders at the top of the file. 4 - Try http://yourserver.com/upload/process.jsp in your browser and upload one file. 5 - If it works, then you can install JFileUpload. 6 - Copy JFileUpload files and folder under the upload/ folder 7 - Setup "url" parameters in applet_http.js with http://yourserver.com/upload/process.jsp 8 - Try the applet in browser with http://yourserver.com/upload/applet_http.html |
