Overwrite
Overwrite
Postby vlad » Thu Sep 20, 2012 6:00 pm
I am using the applet to download folders, recursively, via HTTP. I have the following parameters set:
<PARAM NAME="item1" VALUE="Files">
<PARAM NAME="param2" VALUE="relativefilename">
<PARAM NAME="value2" VALUE="true">
<PARAM NAME="overwrite" VALUE="false">
<PARAM NAME="resume" VALUE="true">
<PARAM NAME="folderdepth" VALUE="-1">
<PARAM NAME="authentication" VALUE="auto">
<PARAM NAME="encoding" VALUE="UTF-8">
My folder "Files" has one single file. If I am downloading the folder multiple times, choosing the same location, the applet is overwriting my file every time and it the local file is only downloaded partially, it doesn't ask to resume. I never get the prompt I see in the screenshot on this website.
Vlad
vlad
Re: Overwrite
Postby support » Fri Sep 21, 2012 6:37 am
Important parameters to get pop-up are:
But you already have them.
What about in18_pane.properties, does it load?
Do you have:
<PARAM NAME="transferuiresources" VALUE="i18n_pane">
Re: Overwrite
Postby vlad » Fri Sep 21, 2012 8:40 am
Yes, I have also the following two:
<PARAM NAME="resources" VALUE="i18n_bar">
I made no changes to the two configuration files.
Just can't make the applet ask me about overwriting or resuming.
vlad
Re: Overwrite
Postby vlad » Fri Sep 21, 2012 2:57 pm
Another question. Can I merge "i18n_bar.properties" and "i18n_pane.properties" into a single file? I don't want to have the applet download two separate files for the same purpose.
vlad
Re: Overwrite
Postby support » Sat Sep 22, 2012 8:43 am
No, you cannot merge. You must have 2 files.
Re: Overwrite
Postby vlad » Sat Sep 22, 2012 9:51 am
I have merged the contents of the files set the same filename for both resources:
<PARAM NAME="resources" VALUE="java_download_locale">
<PARAM NAME="transferuiresources" VALUE="java_download_locale">
<PARAM NAME="localeresources" VALUE="false">
<PARAM NAME="localeresourcesextension" VALUE=".php">
It works, but of course the applet is making two separate requests. At least some server-side HTTP caching will work after the first request to speed it up. The thing is, the file "i18n_pane.properties", if you remove the commented lines, it is very small and it doesn't really deserve a file of its own.
Anyway, this is not very important, more of a cosmetic thing. The overwrite problem is very important and still can't make it work. No idea what to try next.
vlad
Re: Overwrite
Postby support » Tue Sep 25, 2012 7:59 pm
So if your .properties are OK, then it's a problem with the server-side script (i.e. process.php + explorer.php). If you look at the online demo, does it prompt for resume/overwrite?
http://www.jfileupload.com/products/dem ... nload.html
Here is how it works basically:
- If the file you want to download does not already exist on local folder, applet download files directly.
- If the file you want to download does already exist on local folder, then applet sends an HTTP HEAD request to know remote file size. Then depending on response that includes filesize applet knows if it should prompt either resume or overwrite.
If you're using MD5 for resume, then it will compare local/remote MD5 too.
Here are the HTTP traces you can get by enabling:
<PARAM NAME="verbosemode" VALUE="debug">
[DEBUG] header - >> "HEAD /products/demo/process.php HTTP/1.1[\r][\n]"
[DEBUG] HttpMethodBase - Adding Host request header
[DEBUG] header - >> "Range: bytes=0-156931[\r][\n]"
[DEBUG] header - >> "filename: /samplefile200901.jpg[\r][\n]"
[DEBUG] header - >> "checksum: md5[\r][\n]"
[DEBUG] header - >> "relativefilename: /samplefile200901.jpg[\r][\n]"
[DEBUG] header - >> "User-Agent: JFileUpload[\r][\n]"
[DEBUG] header - >> "Host: www.jfileupload.com[\r][\n]"
[DEBUG] header - >> "[\r][\n]"
[DEBUG] header - << "HTTP/1.1 200 OK[\r][\n]"
[DEBUG] header - << "Date: Tue, 25 Sep 2012 19:43:53 GMT[\r][\n]"
[DEBUG] header - << "Server: Apache[\r][\n]"
[DEBUG] header - << "X-Powered-By: PHP/5.2.17[\r][\n]"
[DEBUG] header - << "Connection: close[\r][\n]"
[DEBUG] header - << "size: 156931[\r][\n]"
[DEBUG] header - << "checksum: 782bea7295d8a477c42a9c2e5bf8b9a0[\r][\n]"
[DEBUG] header - << "Vary: Accept-Encoding,User-Agent[\r][\n]"
[DEBUG] header - << "Content-Type: text/html; charset=UTF-8[\r][\n]"
[DEBUG] header - << "[\r][\n]"
[DEBUG] HttpMethodBase - Should close connection in response to directive: close
[DEBUG] HttpConnection - Connection is locked. Call to releaseConnection() ignored.
[DEBUG] HttpConnection - Releasing connection back to connection manager.
[INFO] G - Head Status code = 200
[DEBUG] HTTPDownloadTransfer - localfolder:C:\Users\Documents
[DEBUG] HTTPDownloadTransfer - account:C:\Users\Documents
[DEBUG] HTTPDownloadTransfer - relativefilename:true
[INFO] HTTPDownloadTransfer - Download (POST) started : /samplefile200901.jpg
[DEBUG] HttpConnection - Open connection to www.jfileupload.com:80
network: Connexion de http://www.jfileupload.com:80/ avec proxy=DIRECT
[DEBUG] header - >> "POST /products/demo/process.php HTTP/1.1[\r][\n]"
[DEBUG] header - >> "filesystem: jfileupload.download.http.HTTPDownloadTransfer[\r][\n]"
[DEBUG] header - >> "localfolder: C:\Users\Documents[\r][\n]"
[DEBUG] header - >> "account: C:\Users\Documents[\r][\n]"
[DEBUG] header - >> "relativefilename: true[\r][\n]"
[DEBUG] header - >> "Content-Length: 41[\r][\n]"
[DEBUG] header - >> "Content-Type: application/x-www-form-urlencoded[\r][\n]"
[DEBUG] EntityEnclosingMethod - Request body sent
[DEBUG] header - << "Date: Tue, 25 Sep 2012 19:44:01 GMT[\r][\n]"
[DEBUG] header - << "Content-Length: 156931[\r][\n]"
[INFO] HTTPDownloadTransfer - Status code = 200
[INFO] HTTPDownloadTransfer - Download completed
Return to JFileDownload
