My customer ask me about exception involve to download. It is not show error message when they remove network cable .
Your jfiledownload have that exception and how to show error message when downloading file which network failed.
I'm very appreciate if you have any reply.
Exception download when removing network Cable
Re: Exception download when removing network CableCould you post the Exception you get in Java console?
Re: Exception download when removing network CableWhen i remove Lan cable while downloading file , how can it get post param of exception . -But when download a file existing at client. It have message "java.net.SocketTimeoutException:Read timed out" -Download file without overwriting, it not show message similar above <--does jfiledownload have exception message when downloading normal file ? Re: Exception download when removing network CableWe will try to reproduce the last item you reported that does not show exception.
