User Accounts (folders)
Amazon S3 explorer add-on.
nicholas
Post by nicholas »
I find your product very useful. I was wondering if there is a way to restrict access to users of my website to only specific parts of the bucket. I am trying to allocate to each user of my website their (virtual) folder in which they can upload, download or delete their files.
As uploading is concerned, I will just append their username in front of the file names so the files are part of the username folder. My question is how can I make the user log automatically to my S3 bucket and only display to him his folder, without allowing him to have access to other user folders?
Thank you,
Nicholas
Re: User Accounts (folders)
Yes, you define on folder per user. For example for user1 folder try:
<PARAM NAME="param8" VALUE="account">
<PARAM NAME="value8" VALUE="user1">
Does it help?
