PHP upload fails with filename including quote
All others add-ons (Secure FTP, SCP, Flickr, scripts ...).
If you have some filenames including quotes such as abc'and''test.zip then PHP upload script could all the beginning. Then the uploaded filename becomes test.zip.
This problem is not related to the upload applet but to the way PHP is setup on your server.
See: http://us3.php.net/features.file-upload
To solve it, you have to turn magic_quotes_gpc to off either in php.ini or in .htaccess.
For php.ini, search for:
; Magic quotes for incoming GET/POST/Cookie data.
magic_quotes_gpc = Off
For .htaccess, put the following line into the .htaccess file:
php_flag magic_quotes_gpc off
See: http://www.php.net/manual/en/security.m ... .php#55935
Hope it helps.
