Leading space in directory name
plimpton
Post by plimpton »
I've come across a bug I believe. If there's a leading space in the directory name you're not able to delete the directory.
Re: Leading space in directory name
A folder starting with space? or any space in a folder name?
plimpton
Post by plimpton »
Only if it starts with a space. The app allows it to be created with a prepended space, but doesn't allow you to delete or navigate to that newly created folder. It replaces any spaces appended to the end with an underscore, but not the prepended spaces. It allows spaces in the middle and everything works just fine
Ok, I will try to reproduce the problem. Is it with HTTP or FTP?
plimpton
Post by plimpton »
FTP, I haven't tried HTTP
Could you make the same test with a folder within another folder?
Problem reproduced.
Which FTP server are you using?
plimpton
Post by plimpton »
Just our company's server ftp.bitgravity.com
Which is ProFTPd or IIS ?
plimpton
Post by plimpton »
We use a modified version of PureFTPd
