ImageReadParam num source and dest bands differ
Image previewer add-on.
maarora
Post by maarora »
I am geeting the error message while uploading the jpg image "Error: ImageReadParam num source and dest bands differ". I am integrating the jimageupload in the php scripts. Though jupload loads properly but it shows the error message while i try to upload the jpg file. Can anybody help ??
Regards,
Manish
Re: ImageReadParam num source and dest bands differ
Are you trying to upload a grayscale image ?
Could you attach your image in this post ?
maarora
Post by maarora »
yes I was using the grey image. It has been resolved now. Thx
Grayscale issue has been fixed in next release (2.1). The online demo has already been updated with the fix.
