Recursive folder
Image previewer add-on.
jrobinet
Recursive folder
Post by jrobinet »
I am playing with jimageupload, everything works fine but the recursive folder stuff. It is working without the jimageupload (jfileupload) as soon as I plug it in it's not working anymore. Below the parameters:
document.writeln('<PARAM NAME=ARCHIVE VALUE="lib/jfileupload.jar,lib/httpimpl.jar,lib/chttpclient.jar,lib/clogging.jar,lib/previewui.jar">');
document.writeln('<PARAM NAME="url" VALUE="http://www.silvertest.fr/applet/upload.php">');
document.writeln('<PARAM NAME="transferui" VALUE="jfileupload.transfer.client.preview.PreviewerTransferUI">');
document.writeln('<PARAM NAME="resources" VALUE="i18n_bar">');
document.writeln('<PARAM NAME="transferuiresources" VALUE="i18n_pane">');
document.writeln('<PARAM NAME="folderdepth" VALUE="1">');
document.writeln('<PARAM NAME="param2" VALUE="relativefilename">');
document.writeln('<PARAM NAME="value2" VALUE="true">');
I have the following error in the java console
18 mai 2010 19:45:14 jfileupload.transfer.client.http.HTTPUploadTransfer run
INFO: Upload failed - Files requirements
Thanks in advance
/jm
Re: Recursive folder
What is the depth of folders and subfolders? I see you have:
For unlimited folders/subfolders it should be:
<PARAM NAME="folderdepth" VALUE="-1">
