File appends instead of resuming
ShallowFellow
Post by ShallowFellow »
I'm new to jFileDownload, and when I attempt to resume a file download, it goes past 100% and just appends the extra to the end of my existing file. Is there some parameter I'm missing? I'm using an IIS server. Here's my current config:
document.writeln('<PARAM NAME=ARCHIVE VALUE="lib/jfileupload.jar,lib/ftpimpl.jar,lib/cnet.jar,lib/clogging.jar,lib/download.jar">');
document.writeln('<PARAM NAME="resume" VALUE="true">');
document.writeln('<PARAM NAME="overwrite" VALUE="false">');
document.writeln('<PARAM NAME="url" VALUE="ftp://dev.mycompany.com">');
document.writeln('<PARAM NAME="item1" VALUE="myfilename">');
document.writeln('<PARAM NAME="username" VALUE="administrator">');
document.writeln('<PARAM NAME="password" VALUE="password">');
document.writeln('<PARAM NAME="param6" VALUE="account">');
document.writeln('<PARAM NAME="value6" VALUE="MYFOLDERPATH">');
document.writeln('<PARAM NAME="folderdepth" VALUE="-1">');
document.writeln('<PARAM NAME="transferui" VALUE="jfileupload.download.ui.DownloadTransferUI">');
document.writeln('<PARAM NAME="resources" VALUE="i18n_bar">');
document.writeln('<PARAM NAME="transferuiresources" VALUE="i18n_pane">');
document.writeln('<PARAM NAME="mode" VALUE="jfileupload.download.ftp.FTPDownloadTransfer">');
EDIT: I'm using the FTP download.
Thanks!
Re: File appends instead of resuming
Could you provide a testing FTP account to support(at)jfileupload(dot)com?
It might be a problem with the REST FTP command.
ShallowFellow
Can I private message it somehow?
EDIT: Also, if it is a REST issue, how ca I fix it? I'm running IIS.
Just send me email to support(at)jfileupload(dot)com
Also: http://www.jfileupload.com/products/jfi ... aq.html#44
I've made a test with FileZilla (which is a regular FTP client) and I've exactly the same problem. Which version of IIS FTP server do you have?
Did you see the following known issue under IIS6:
http://support.microsoft.com/kb/915179
