Path issues
jmaster
Path issues
Post by jmaster »
Hello again,
I am having issues with download from folder's subfolders. For example:
download folder path: www.abc.com/members/download
specific subfolder path: www.abc.com/members/download/suzie
The following works, but it downloads everything under /download
document.write('item1="download" ');
The following does not work:
document.write ('item1="download/suzie" ');
Settings:
document.write('param2="relativefilename" ');
document.write('value2="true" ');
It seems that only single folder works but not selection on specific subfolder(s).
Any help will be appreciated.
Cheers,
JM.
Re: Path issues
Try:
<PARAM NAME="url" VALUE="http://www.abc.com">
<PARAM NAME="folderdepth" VALUE="-1">
<PARAM NAME="param4" VALUE="relativefilename">
<PARAM NAME="value4" VALUE="true">
<PARAM NAME="param5" VALUE="account">
<PARAM NAME="value5" VALUE="members/download">
<PARAM NAME="item1" VALUE="suzie">
Does it help?
You have samples at:
http://www.jfileupload.com/products/jfi ... n/samples/
