Maximum File Size
Rumnor
Maximum File Size
Post by Rumnor »
just wondering if there is a limit on the file size you can download using the JFileDownload?
I've in the past used the following:
http://www.javaatwork.com/java-file-dow ... tails.html
It works well for files, which are upto 3GB in size, but anything higher it doesnt like! Also there support is shocking :evil:
Look forward to a response.
Chod
Re: Maximum File Size
Yes, it should work for > 3GB files. Do you plan HTTP download only or FTP too ?
Rumnor
Post by Rumnor »
HTTPS for download and FTP for upload eventually.
Ok, it should work fine for HTTP(S). Just pay attention if you download a 4GB file because the target folder must not be formatted as FAT16 which is limited to 4GB file size.
